Eyy Clabbe!Vad är det för märke?Aldrig hört talas om det.
Från USA antar jag.Vem tippsa dig om det?
Inte för att jag ska köpa insug till min,då orginal håller riktigt hög standard.Men det kan ju vara kul att veta [img]http://www.hondaklubben.com/forum/style ... /smile.gif[/img]
Vad köpte du sist till bilen?
AEBS Typhoon Intake Manifold is intended to be the ultimate street performance manifold. Unlike all-out racing manifolds, good bottom end power is retained. The JDM manifold is quite expensive while the Typhoon, an improved version of the JDM, is much less costly. Typhoon is patterned after the popular JDM Type R manifold with some additional refinements. The plenum chamber has been lengthened to provide additional plenum volume when used with a supercharger, turbo or nitrous applications. This reduces starvation of last port runner, a common problem with stock manifolds. Nitrous bosses are located on the underside of the manifold. Available in half-polished and satin finish. Features a 65mm inlet.
Typhoon features:
Nitrous Bosses on underside of runners
65mm diameter inlet to plenum chamber
Plenum longer and larger than stock
Least expensive HP manifold available
All vacuum ports moved to back side
Areas between runners webbed for appearance and better polished finish
The Typhoon has been dyno'ed on a stock JDM Integra Type-R w/ Greddy exhaust with an average increase of 12-15hp at the wheels between 3000-8000rpm.
taget från http://www.nipponpower.com
Typhoon features:
0709-138741
Medlem #368
Medlem #368
- *PAPPOUS*
- Bil: Civic EK20
- Namn: Christian Kutsudakis
Tackar Henrik [img]http://www.hondaklubben.com/forum/style ... humbup.gif[/img]
Honda Civic EK4 -00
N/A is the shit!
All motor K20
"knock ::knock: whos there? your rods muthafuckaaa"
N/A is the shit!
All motor K20
Clabbe
- Bil: RD9
- Namn: Клабе Бюрстром
Precis...
Har fått en massa bra kritik på Honda-Tech i jämnförelse mot OEM Type-R och Skunk2.. Så det blir att testa ett sånt här iår.. [img]http://www.hondaklubben.com/forum/style ... lleyes.gif[/img]
Благодаря мутра!
- *PAPPOUS*
- Bil: Civic EK20
Värkar ju riktigt nice det där Clabbe.
Vad ligger priset på och var köper man det?
Bra att veta sånt ju [img]http://www.hondaklubben.com/forum/style ... /smile.gif[/img]
Honda Civic EK4 -00
N/A is the shit!
All motor K20
N/A is the shit!
All motor K20
Clabbe
- Bil: RD9
Behöver du fråga? [img]http://www.hondaklubben.com/forum/style ... >/oops.gif[/img]
Благодаря мутра!
- *PAPPOUS*
- Bil: Civic EK20
You lost me [img]http://www.hondaklubben.com/forum/style ... #>/sad.gif[/img]
Ebay eller?
Ebay eller?
Honda Civic EK4 -00
N/A is the shit!
All motor K20
N/A is the shit!
All motor K20
Glöm inte vem som hittade det Clabbe! Och vem du handlar av.
Endoor
Medans jag e stuck med the leftovers [img]http://www.hondaklubben.com/forum/style ... /w00t2.gif[/img]
dodo
- Bil: civic vt-turbo
- Namn: Daniel carlsson
<!--QuoteBegin-Clabbe+2 Nov 2004, 22:08:44--><div class='quotetop'>QUOTE(Clabbe @ 2 Nov 2004, 22:08:44)</div><div class='quotemain'><!--QuoteEBegin-->Beställde Precis ett nytt AEBS Typhoon insug till min ännu oinhandlade B16 topp!
kan du ta hem ett till
<!--QuoteEnd--></div><!--QuoteEEnd-->kan du ta hem ett till
team varberg
honda crx vt e85
honda civic vt-t
honda accord type-s
bmw 318is m50
honda crx vt e85
honda civic vt-t
honda accord type-s
bmw 318is m50
kan nog även handlas på http://www.nipponpower.com där jag hämtade texten ifrån [img]http://www.hondaklubben.com/forum/style ... >/wink.gif[/img]
0709-138741
Medlem #368
Medlem #368
Clabbe borde bli officiell handhavare för Ebay i klubben, hittar allt möjligt bra [img]http://www.hondaklubben.com/forum/style ... iggrin.gif[/img]
Simon Aunér
F.d. ägare av en Honda Accord 2.3i SR 1994
Jag kan ta hem fler om det finns intresse.
- NickeCivicVTi
- Bil: Civic VTi
- Namn: Nicklas Ekström
Mmmmmmm! Med dessa ska ladda sej lite! [img]http://www.hondaklubben.com/forum/style ... iggrin.gif[/img]
Senast redigerad av NickeCivicVTi den 3 november 2004, 19:40, redigerad totalt 1 gånger.
Nicklas Ekström-Sthlm
Honda Civic VTi -92 (under konstruktion)
<!--QuoteBegin-M Scotte+3 Nov 2004, 14:00:48--><div class='quotetop'>QUOTE(M Scotte @ 3 Nov 2004, 14:00:48)</div><div class='quotemain'><!--QuoteEBegin-->Jag kan ta hem fler om det finns intresse.<!--QuoteEnd--></div><!--QuoteEEnd-->
Pris?
Pris?
Henrik Mårdh #248
Civic VT-91 *renovering pågår*
Civic EK4 -00 *såld*
SAAB 9-5 2.3T kombi -01 *Familjepulkan**såld*
Civic 1.8 Sport -11 *Nya familjepulkan*
SCRAM
SCRAM
Clabbe
- Bil: RD9
*HOST* *HARKEL* [img]http://www.hondaklubben.com/forum/style ... lleyes.gif[/img]
<a href="http://www.hondaklubben.com/forum/index ... c=4734&hl=" target="_blank">http://www.hondaklubben.com/forum/index ... 734&hl=</a>
Благодаря мутра!
<!--QuoteBegin-Clabbe+3 Nov 2004, 18:26:12--><div class='quotetop'>QUOTE(Clabbe @ 3 Nov 2004, 18:26:12)</div><div class='quotemain'><!--QuoteEBegin-->*HOST* *HARKEL* [img]http://www.hondaklubben.com/forum/style ... lleyes.gif[/img]
<a href="http://www.hondaklubben.com/forum/index ... c=4734&hl=" target="_blank">http://www.hondaklubben.com/forum/index ... uoteEEnd-->
Jaja jag såg det nu. [img]http://www.hondaklubben.com/forum/style ... >/oops.gif[/img] Man börjar ju läsa forumet uppifrån och ner. [img]http://www.hondaklubben.com/forum/style ... >/wink.gif[/img]
Henrik Mårdh #248
SCRAM
SCRAM
- *PAPPOUS*
- Bil: Civic EK20
Fick hem en avi i brevlådan iag.Det gällde min nya fina vinge.10 veckors väntetid [img]http://www.hondaklubben.com/forum/style ... >/prop.gif[/img]
Ska hämta den på måndag morgon.Återkommer med bilder [img]http://www.hondaklubben.com/forum/style ... humbup.gif[/img]
Honda Civic EK4 -00
N/A is the shit!
All motor K20
N/A is the shit!
All motor K20
dessa fälgar till R-däcken...
Speedbleeders
Trailinglinkbussning
Russels stålomspunna slangar
Speedbleeders
- *PAPPOUS*
- Bil: Civic EK20
woot!woot!
Var precis och hämtade min fina Type R spoiler som WingsWest tog 2 månader på sig att tillverka.
Till alla ni med EK:spring inte ock köp en likadan nu
Honda Civic EK4 -00
N/A is the shit!
All motor K20
N/A is the shit!
All motor K20
åh fan en sån där måste jag också ha! [img]http://www.hondaklubben.com/forum/style ... >/wink.gif[/img]
skämt åsido.. det kommer att bli coolt det där!
Jonatan Forsberg
Härnösand
Härnösand
Endoor
Oh shit Christian!
Betalade du för WW vingen?
Jag har gått o kollat på den i flera år men aldrig tyckt priset motivera stylingvärdet tvärr.
grymt att du högg en! GRattis o jaaaa jag e lite avis [img]http://www.hondaklubben.com/forum/style ... #>/wub.gif[/img] [img]http://www.hondaklubben.com/forum/style ... /blush.gif[/img]
- *PAPPOUS*
- Bil: Civic EK20
Tack grabbar [img]http://www.hondaklubben.com/forum/style ... humbup.gif[/img]
Den gick loss på 3400 ink frakt.Helt okej tycker jag om man jämnför mot en äkta vinge från EK9 som ligger runt 1000 dollar [img]http://www.hondaklubben.com/forum/style ... /blink.gif[/img]
Honda Civic EK4 -00
N/A is the shit!
All motor K20
N/A is the shit!
All motor K20
<!--QuoteBegin-*PAPPOUS*+8 Nov 2004, 09:27:25--><div class='quotetop'>QUOTE(*PAPPOUS* @ 8 Nov 2004, 09:27:25)</div><div class='quotemain'><!--QuoteEBegin-->Tack grabbar [img]http://www.hondaklubben.com/forum/style ... humbup.gif[/img]
Den gick loss på 3400 ink frakt.Helt okej tycker jag om man jämnför mot en äkta vinge från EK9 som ligger runt 1000 dollar [img]http://www.hondaklubben.com/forum/style ... /blink.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
Nice wing [img]http://www.hondaklubben.com/forum/style ... humbup.gif[/img]
Keith Shearer
90 teg
90 teg
Clabbe
- Bil: RD9
Å så blidde det en B16 topp! [img]http://www.hondaklubben.com/forum/style ... humbup.gif[/img]
Благодаря мутра!
Ejan
- Bil: Ford Fiesta 2010
- Namn: Erik Leander
jag kostade på Rexen en besiktning och den vart glad o gick igenom prickfritt [img]http://www.hondaklubben.com/forum/style ... humbup.gif[/img]
#738
1999 Honda Integra Type R - 208bhp - SÅLD
Kör numera Ford Fiesta ST´05
Clabbe
- Bil: RD9
Å så blidde det 2st oljekylare med splittny adapter och nya slangar [img]http://www.hondaklubben.com/forum/style ... humbup.gif[/img]
Благодаря мутра!
Clabbe
- Bil: RD9
Sen råkade jag handla en uppsättning Legendok idag oxå... [img]http://www.hondaklubben.com/forum/style ... lleyes.gif[/img]
Och Cup-speglar oxå.. [img]http://www.hondaklubben.com/forum/style ... stling.gif[/img]
Благодаря мутра!
